Sign up Log in
Need a Groovy Script for Validating multi-checkbox field or Current user is in Admin role
siva
Can any one provide Groovy Script
Need a validator Script for.
1. All the check boxes in the field are selected ( or ) Current user is in developer role in project.
Both the conditions need to be in the script.
Tried few scripts but the selection of all the checkboxes wont work.
PD Sheehan
October 30, 2019
A checkbox returns a list of selected options.
You'll need to compare that list of selected (checked) options against the list of available options for that field in the current context.
This should work in a simple scripted validator (in your workflow)
//for this you'll need a customfield object for the checkbox field
def cf = ComponentAccessor.customFieldManager.getCustomFieldObjectByName('my checkbox field')
//So that you can get the configuration context
def config = cf.getRelevantConfig(issue)
// and the list of associated options
def cfOptions = ComponentAccessor.optionsManager.getOptions(config)
//then, for good measures, get the list of values in a sorted order so you can compare them. Sorting may not be necessary, I suspect the order will alway be the same, but it can't hurt
cfOptions*.value.sort() == cfValues['my checkbox field']*.value.sort() || isUserMemberOfRole('Developers')
siva
Thank you,
worked out with another script and tested this   no defects.
Like Sebastián Molina Meza likes this
