Need ability to set 'rank' for new tickets tickets
Veera rdy March 26, 2018 edited
We're using a Script rest end point api to create a Jira issue. We need a way to order the incoming tickets. Is there a way to set the rank for issues on creation.
Please advice.
Thanks.
Andy Heinzer
March 30, 2018
The Rank field is utilized by Jira Software for all issues in Jira.   When an issue is created Jira Software will generate an initial rank value for these.  This happens shortly after the issue created.  But this is not happening at the time the issue is created.
Since this is a system field, I would not recommend trying to set a value for this field manually, or via some other process outside of Jira Software's own ranking methods.  At least not in regards to using the specific REST endpoint api/2/issue
Even if you add that rank field to the screen scheme, you are not expected to be able to set a value for this at the precise time the issue is created via this method.
There is another REST endpoint you can use to set a rank value after the issue has been created though, please see agile/1.0/issue - Rank issues.   If you want to set a rank value via REST, this is the way to do so.
It might still be possible to define the rank value when the issue is created, but the only method I know of that might be able to do this when creating issues is the method via the CSV external system import in Jira.  I believe that the importer plugin Jira is using is able to set the value of a rank field this way on import.  But this is not the same thing as creating an issue via REST.
Vladimir Virlan
@Andy Heinzer thanks for your reply. Any chance of setting rank in jira Cloud? Thanks
Andy Heinzer
November 23, 2021
For Jira Cloud there is a REST API endpoint as well in PUT /rest/agile/1.0/issue/rank  that can set the Rank of an issue.  However this can only be used for issues that already exist within Jira.  This does not create new issues as the original post asked to be able to do.
Like 2 people like this
Vladimir Virlan
Many thanks @Andy Heinzer that works well.
Like Bruno likes this
