Hi
I need that plugin but it's not supported on Jira Cloud.
Do you know a good alternative that works on cloud?
Thank you
Hi Mosh,
I searched for similar add-ons, but there are no add-ons that have all the functionalities, maybe you will have to use more than one to have the same options as the one you mentioned.
I would suggest you contact their support to ask if they have plans or if they are developing a Cloud version for the add-on.
Angélica
Read the story
