Need help adding a transition
Frank_Sobczynski
HI all,
I need to add a transition from Closed to In Progress and I keep getting the following error message:
You are editing a draft workflow. The step 'Closed' has no outgoing transitions in the Active workflow, so you cannot add any outgoing transitions in the Draft workflow.
2 accepted
Ravi
March 27, 2019
@Frank_Sobczynski
The following limitations apply when editing the draft for an active workflow:
  • It is not possible to edit the workflow name (only the description) if a workflow is active.
    Workflow statuses cannot be deleted.
  • If a status has no outgoing transitions (Global transitions are not considered), it cannot have any new outgoing transitions added, regular or global.
  • The step ID cannot be changed. See Cannot Add Transitions or Delete Steps in Draft Workflows.
  • To make any of the modifications listed above, you need to copy the workflow, modify the copy, and then activate it.
 Here is the complete documentation https://confluence.atlassian.com/adminjiraserver072/working-with-workflows-828787890.html
Joe Pitt
You need to copy the current workflow, edit it, and then assign it to the project. As the error says, you don't have an outgoing transition already in the workflow.
yoko ishioka
July 20, 2024
ty!!!
Frank_Sobczynski
Thank all! It is now fixed.
