Need help on weighted score field scrip
tazeenn March 8, 2019 edited
Hi have script runner installed and I am looking for a script that will help in calculating these scenario
The script shall be applied on total score field which will be populated based on the values in 3 fields which also has some weight
  • BV - 1
  • CV -2
  • Tech COmplexity 1
The formula in excel is =(CV*2)+(BV*1)+(TV*1)
The formula multiplies the column values with weight.
Can someone help with the script to write this formula in JIRA
Ravi Sagar _Sparxsys_
March 8, 2019
Hello @tazeenn
You need to write a Script field for this.
You can find more information here: https://scriptrunner.adaptavist.com/5.5.0/jira/scripted-fields.html
For some examples check out http://library.adaptavist.com
Ravi
