Need some help to install Jira Software to a VPS with Webmin
Anton Perera February 27, 2019
Hi everyone,
I was trying to install Jira Software to a VPS with Webmin. Anyone has previous experience or any links or guides ?
Thanks.
Nic Brough -Adaptavist-
February 28, 2019
You can't do it with Webmin.  To install Jira, you need command line access so that you can run the installer (or unpack a packaged file).
Anton Perera February 28, 2019 edited
Hi Nic,
Thanks for the response. Yeah I was looking for any guide on command line installation as the .bin file installation failed. With my further research I have found this guide and it was very helpful. Already followed many steps.
https://confluence.atlassian.com/adminjiraserver/installing-jira-applications-on-linux-from-archive-file-938846844.html
But installation failed with saying this
Wrong JVM version! You are running with .. but JIRA requires at least 1.8 to run
But when I checked java version with "java -version" command and the result is
openjdk version "1.8.0_181"
March 3, 2019
That suggests the JAVA_HOME is being set incorrectly for the service.  Check what is being set in setenv.sh
Like Anton Perera likes this
Anton Perera March 4, 2019
Yeah I thought the same and tried the resetting JAVA_HOME but didn't worked and had to try another workaround found on this community which suggested to change the line below in <Jira-installation-files>/bin/check-java.sh file
Thanks mate for the support.  :)
_EXPECTED_JAVA_VERSION="8"
to
_EXPECTED_JAVA_VERSION="0"
Register Now
