Need to Auto Populate the Target Completion date Field based on Priorities
Venkata Sagar April 20, 2022
When Priority is set in the Bug ticket OR When Priority is modified to a new Priority Value, auto populate the "Target Completion Date" with a date based off the following time duration per Priority Level measured from the time of ticket creation:
For example, if a ticket is created on 8/20/21, and the Priority is set to P1 on 8/24/21, then the Target Completion Date should be auto populated to 9/24/21
Another example - if a ticket previously was a P1, then its priority is modified to P2, and its original Target Completion Date was 10/5/21, then the Target Completion Date needs to be auto-updated to 11/9/21
robert Mugabuhamye
April 20, 2022
Hello @Venkata Sagar ,
You can easily do this using Automation for Jira.
You can create an automation with:
  • trigger = Field values change → field being priority
  • using if/else condition to switch through P0 to P3
    • action : edit field Target Completion date
      • using the function plusweeks
      • something like {{created.pluweeks(3)}}
Regards
atlassian, atlassian community, loom ai, atlassian loom ai, loom, atlassian ai, record recaps of meetings, meeting recaps, loom recaps, share meeting recaps,
Loom’s guide to great meetings 📹
Register today!
