×Hi Team,
i am working on below requirement:
If the User will select a particular value in Components field "MV1.1" the the Due date for the issue should be cleared . I am not sure whether this possible or not but just wanted to check the feasibility of this. Please let me know. Thanks!
--Avinash Gautam
Hi Avinash
You can implement an Issue Updated listener. You can either build your own add-on, or use ScriptRunner which makes it more simple.
https://scriptrunner.adaptavist.com/4.3.5/jira/listeners.html
In the listener, you can check for the Component and update other fields to meet your requirement.
Cheers
Bhushan
You need a postfunction for this.
Easiest way to get this - script postfunction provided by ScriptRunner plugin. Can you use this plugins?
