Need to add customised label if a custom field has value
Naveen kumar December 4, 2024
I have created a scripted custom field and if the field is not empty i want Incident to be added as label in the ticket along with other labels and if its empty i want No_Incident to be added in the ticket. I have tried my best to create the script using behaviours but none of them works. can you helpme with the script please. I have script runner and dont have jira automation plugin.
script:
import com.onresolve.jira.groovy.user.FieldBehaviours
import groovy.transform.BaseScript
@BaseScript FieldBehaviours fieldBehaviours
def customFieldA = getFieldById("customfield_25202")
def customFieldValue = customFieldA.getValue()
def labelsField = getFieldByName("Labels")
if (customFieldValue ) {
    labelsField.setFormValue(['Incident'])
} else {
    labelsField.setFormValue(['No_incident'])
This script is not working , not sure where it went wrong
Tuncay Senturk
December 4, 2024
Hi @Naveen kumar
I don't know what you're seeing when you run the code but I'd change it as below to update labels without overwriting existing ones.
def existingLabels = labelsField.getValue() as List ?: []
if (customFieldValue) {
if (!existingLabels.contains('Incident')) {
existingLabels.add('Incident')
// Remove 'No_incident' if present
existingLabels.remove('No_incident')
} else {
if (!existingLabels.contains('No_incident')) {
existingLabels.add('No_incident')
// Remove 'Incident' if present
existingLabels.remove('Incident')
labelsField.setFormValue(existingLabels)
Naveen kumar December 11, 2024
@Tuncay Senturk not related to this one, can we hide the child option (secondary one of the field) in a cascading field? is there a way to do it ?. If yes can you show me the way please.
Meanwhile ill try with the above code, thanks so much
