Need to bulk update sub-tasks using Scriptrunner
Kaushik Patel April 6, 2020
I want to bulk update one field of multiple sub-tasks.
This field is issue summary field or it is called task title.
I tried using JIRA bulk update feature but I didn't find the issue summary field to bulk update.
I have ScriptRunner installed. Can this be accomplished by ScriptRunner?
If so, I would need help with query.
e.g. I want to set issue summary field for multiple sub-tasks to "Test sub-tasks".
I have list of sub-tasks for which I need to make the bulk update.
Kaushik.
Leo
April 6, 2020 edited
Hi @Kaushik Patel,
Below is the sample script which I run in script console to update issue's summary
import com.atlassian.jira.issue.IssueManager;
import com.atlassian.jira.event.type.EventDispatchOption;
def issue = ComponentAccessor.issueManager.getIssueByCurrentKey("PARENT-23")
def subtasks = issue.getSubTaskObjects()
def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
subtasks.each{ subtask ->
def sb = subtask as MutableIssue
sb.setSummary("Summary from console")
ComponentAccessor.getIssueManager().updateIssue(user,sb,EventDispatchOption.ISSUE_UPDATED, true)
 hope this gives you some idea
BR,
Leo
Kaushik Patel April 12, 2020
Thank you Leo. This solution worked.
Appreciate the timely help.
Learn more
