Need to create a filter based upon the Project Lead
Jeff White
October 4, 2013
At my company, the Project Lead is the ultimate owner of each issue. Is there a way to build a filter that includes this criteria? I don't see Project Lead as a field.
9 votes
Jeff White
October 15, 2013
on of my guys here figured it out .
OR project IN projectsLeadByUser())
Carmen Cismas
April 24, 2018
This worked for me perfect :) Thanks!
אריג' חמדאן March 2, 2019
For me also.
Thanks a lot for sharing.
Jason Herz December 31, 2019
thank you! perfect!!!
Srikanth Ganipisetty
Perfect, thanks! Here is the link for more JQL functions on JIRA.
JQL functions in JIRA
Bob Campbell May 1, 2014
For anyone coming across this thread see also https://jira.atlassian.com/browse/JRA-10673
Jeff White
October 6, 2013
That's pretty much what I'm looking for. Where is the JQL Tricks Plug in? Is it available in the On Demand version of JIRA/Tempo?
Jobin Kuruvilla [Adaptavist]
October 6, 2013
It is available on marketplace but unfortunately not available for onDemand. I should also say that it is a paid plugin.
Abhijit Mandal
December 26, 2013
i am using rest Api and licenced jira,
but not able to get the project for a projectLead.
please help me..
October 4, 2013
The JQL Tricks plugin has a projectLead function which can be used to filter issues. For example,
assignee = projectLead("XYZ")
This isn't working, unfortunately. It says the JQL function isn't available
Jason Herz December 14, 2020
I found that projectsLeadByUser() requires either 'currentuser()' or the user GUID not their user ID, ie projectsLeadByUser(559058:d6094997-aa6b-40b3-b25a-50f4c5105988)
I think GUID/ID isn't required, I searched the queries with all of my teammate's usernames just now and it worked, even though they're not current login user.
Open for suggestions :)
Please refer JQL in JIRA
personally, I was unable to use the usernames and had to open each user's profile to get their unique ID out of the URL. applying that ID gave me precisely what I needed
Like Srikanth Ganipisetty likes this
Interesting! Is there a reason that we cannot identify the usernames? Is it something that comes from "Browse users" Global Permissions. It's good to know this trick from you @Jason Hertz
