Need to created scripted custom field using script runner
Rajesh Ramankutty
Dear Team,
I need to create a scripted custom field in which if i add an .docx file it should preview the content in the .docx file.
i have a script for .txt file but while m changing according to the .docx files its not working
import com.atlassian.jira.issue.attachment.FileSystemAttachmentDirectoryAccessor
def AttachmentDirecrotryAccessor= ComponentAccessor.getComponent(FileSystemAttachmentDirectoryAccessor)
def output=""
issue.attachments.each {
log.warn "Our File Name : ${it.filename}"
if(it.mimetype == "text/plain" || it.filename.endsWith(".txt"))
def directory = AttachmentDirecrotryAccessor.getAttachmentDirectory(issue)
def file = new File(directory, it.id.toString())
def firstLine = file.withReader { it.readLine()}
output += "$it.filename : <br>$firstLine<br><br>"
log.info "==========================="
log.info output
log.info "============================"
output
Anzar
April 18, 2022
Hi Rajesh,
Docx files in groovy/java can be read only through Apache POI which is not included as a library in script runner.
Hence reading a docx file wont be possible.
Anzar
