Basically what I need is below
I have a custom field 'Special' with values None, A and B as drop-down option. By default the option is set as NONE. A user could change option A or B. When someone choses a value to A or B, an email needs to be send out accoridngly to a fixed email chain.
Need to send out Issue ID and Summary for the issue in the email as well as the current user who set it.
How can I accomplish this?
I tired behaviour plugin as described in this post and also used Mizan's option but think I am don't have the requisite background to code this. Apreciate any help
https://answers.atlassian.com/questions/67193/send-e-mail-notification-after-editing-a-specific-custom-field-in-issue-edit-screen
import com.onresolve.jira.groovy.user.FieldBehaviours import com.onresolve.jira.groovy.user.FormField import com.atlassian.jira.ComponentManager import com.atlassian.jira.issue.Issue import com.atlassian.mail.Email import com.atlassian.mail.server.MailServerManager import com.atlassian.mail.server.SMTPMailServer import org.apache.log4j.Category FormField Special= getFieldById('11240') ComponentManager componentManager = ComponentManager.getInstance() MailServerManager mailServerManager = componentManager.getMailServerManager() SMTPMailServer mailServer = mailServerManager.getDefaultSMTPMailServer() if (mailServer) { Email email = new Email("someuser@example.com") // Set the TO address, optionally CC and BCC email.setSubject("Blocking issue raised by ${issue.getReporter().getFullName()}: ${issue.summary}") // todo: check the subject value String content = "Construct your body here."; //TODO: Set email's body. email.setBody(content) mailServer.send(email) } else { log.error("No SMTP mail server defined") }
Hi Rizwan ,
Use the exact script provided by me .. use fieldChanged instead of your customfield id .
Also the script is for an older version of Jira , there are some api changes which you will need to update . eg: ComponentManager -> ComponentAccessor .
IF you use the above script then it will send an email whenever the user changes the value of the field before submiting it . I think you should use a post function , may be you can use send custom email post function by script runner plugin
