×Hi everyone,
I'm trying to produce an overview over all our projects, their schemes and much more, and I've already found out a lot, but I don't know this:
How do I get the information which Issue Types are available in which projects from the database (SQL Server)?
I want to produce a list with the following columns:
At the moment my SQL looks like this:
SELECT
JIRADB.jiradb.project.id as pid ,
JIRADB.jiradb.project.pkey as pshortcut ,
JIRADB.jiradb.fieldconfigscheme.ID as issueTypeSchemeID ,
JIRADB.jiradb.fieldconfigscheme.configname as issueTypeSchemeName
FROM JIRADB.jiradb.project
JOIN JIRADB.jiradb.configurationcontext
ON JIRADB.jiradb.configurationcontext.PROJECT = JIRADB.jiradb.project.ID
JOIN JIRADB.jiradb.fieldconfigscheme
ON JIRADB.jiradb.fieldconfigscheme.ID = JIRADB.jiradb.configurationcontext.FIELDCONFIGSCHEME
WHERE JIRADB.jiradb.fieldconfigscheme.FIELDID = 'issuetype'
But where do I get the Issue Type ID and Name from?
We're running on Jira Datacenter 9.4.8 and are currently in the process of updating to 9.17.2.
(Unfortunately my formatting has been lost.)
Many thanks and best regards,
Gisela
Hey @Gisela Lassahnto get the Issue Type ID and Issue Type Name in addition to the information you've already gathered, you need to join your existing SQL query with the table that contains issue type definitions. In Jira, this information is stored in the `issuetype` table.
Here’s an updated version of your SQL query that adds the Issue Type ID and Issue Type Name columns:
SELECT
proj.id AS pid,
proj.pkey AS pshortcut,
fieldconfigscheme.ID AS issueTypeSchemeID,
fieldconfigscheme.configname AS issueTypeSchemeName,
issuetype.id AS issueTypeID,
issuetype.pname AS issueTypeName
FROM
jiradb.project AS proj
JOIN
jiradb.configurationcontext AS configcontext
ON configcontext.PROJECT = proj.ID
JOIN
jiradb.fieldconfigscheme AS fieldconfigscheme
ON fieldconfigscheme.ID = configcontext.FIELDCONFIGSCHEME
JOIN
jiradb.optionconfiguration AS optconfig
ON fieldconfigscheme.ID = optconfig.FIELDID
JOIN
jiradb.issuetype AS issuetype
ON optconfig.OPTIONID = issuetype.ID
WHERE
fieldconfigscheme.FIELDID = 'issuetype';
Explanation of Key Joins
You can adjust the specific table and column names based on your database schema, as Jira databases can vary slightly depending on custom configurations and versions.
@Mikel Garcia Bartolome
Many thanks! :-)
But when trying to execute your SQL, I get:
Msg 8114, Level 16, State 5, Line 1
Error converting data type nvarchar to numeric.
In the SQL query, it seems the field jiradb.optionconfiguration.OPTIONID
might be a nvarchar
(string), and jiradb.issuetype.ID
is numeric. SQL Server might be implicitly trying to convert one field to match the other.
First check the data types:
SELECT COLUMN_NAME, DATA_TYPE
FROM INFORMATION_SCHEMA.COLUMNS
WHERE TABLE_NAME = 'optionconfiguration' AND COLUMN_NAME = 'OPTIONID';
WHERE TABLE_NAME = 'issuetype' AND COLUMN_NAME = 'ID';
If OPTIONID
is nvarchar
and issuetype.ID
is numeric, you can cast OPTIONID
to a numeric type for the join. This assumes that OPTIONID
contains valid numeric data.
SELECT
proj.id AS pid,
FROM
JOIN
JOIN
JOIN
ON CAST(optconfig.OPTIONID AS NUMERIC) = issuetype.ID
JOIN
WHERE
Try applying the solution and let me know if it works :)
With this SQL I get:
So I tried it like this:
But as you can see, the result is not like I had expected.
