×For eg -
When status is moved from open to In progress,should get the first date when its moved to In progress using a Scripted field
Try this:
import com.atlassian.jira.issue.changehistory.ChangeHistory
import com.atlassian.jira.issue.changehistory.ChangeHistoryManager
import java.sql.Timestamp
ChangeHistoryManager changeHistoryManager = ComponentAccessor.getChangeHistoryManager()
String fieldName = "Status"
String statusName = "In Progress"
Issue issue = issue as Issue
List<ChangeHistory> allChanges = changeHistoryManager.getChangeHistories(issue)
List<ChangeHistory> cfChanges = []
Timestamp firstChange = null
allChanges.each { ChangeHistory change ->
if (fieldName.toLowerCase() == change.getChangeItemBeans().field[0].toLowerCase()) {
cfChanges.add(change)
if (cfChanges) {
// Additional sorting by date
cfChanges = cfChanges.sort {
it.getTimePerformed()
firstChange = cfChanges.findAll {
it.getChangeItemBeans().toString.first() == statusName
}.first().timePerformed
return firstChange
