×In my Jira project's create screen, need to make LOCATION field mandatory only if Component/s Field's drop down value is "Cloud Test Lines" is selected..
Please help me with script or steps detaily as I am a new bee to Jira.. It will be great help if you people direct me to get it solved immediately.
Anusha Ramesh
Hi @Anusha Iyer
If you have scriptrunner, you can use behaviours to achieve this.
Refer to Thanos answer in https://community.atlassian.com/t5/Jira-questions/Making-custom-fields-invisible-and-mandatory-based-on-component/qaq-p/131311 for a sample script
@Fazila Ashraf: Thanks for the reply, so kind of you.
Yes, I have scriptrunner, could you please help me with the script ?
Unale to understand the concept on https://community.atlassian.com/t5/Jira-questions/Making-custom-fields-invisible-and-mandatory-based-on-component/qaq-p/131311. Please help..
Anusha Ramesh
