I know it's not possible to natively export dashboards.
However, we're merging two instances, and we're desperate to avoid manually recreating 123 shared dashboards.
So, can we work around this, or somehow hack things to get the Dashboard information out of one instance and into another? For example, by dumping the system, carving out the relevant XML, and restoring it? Can we somehow ninja the information using Script Runner?
Any and all answers or thoughts welcome.
I have migrated before using SQL scripts direct. Copying from 1 SQL Server to another. What DB are you using? You'll find you'll also need to migrate filters as many of the dashboard widgets depend on them
The tables are
searchrequest
PortalPage
PortletConfiguration
GadgetUserPreference
FavouriteAssociations
FilterSubscriptions
SharePermissions
Hi Colin,
I have successfully migrated the filters in DB, But I observe a wierd behaviour with dashboards that are migrated. They keep refreshing. Have you seen the similar behaviour?
Regards
Anirudh
OK, I managed to figure that out. The behavior is observed if we use TRUE/FALSE flags for USERPREFKEY colum in Gadgetuserpreference table. I have inserted the records with upper case causing this. I changed the values to lower case and the dashboards are working fine.
We have exactly the same need. Would you be able/agree to share the script ?
Hi Benoit,
Which Database have you got?
I used a dirty way to migrate my who data, used Excel to increment the PKeys and generated the scripts based on that.
Regards
Anirudh
Please vote on this feature request https://jira.atlassian.com/browse/JRA-41104
