I have project and the PM would like two sub-task options. The generic Sub-Task with the blue sub-task icon, AND another sub-task titled Defect with a different icon.
You can create either sub-task and select either Defect or Sub-Task and a sub-task is created. BUT, the resulting sub-task is always being as the Default Sub-task, even if the issue being created was designated as the Defect sub-task
How can I have the resulting issue carry across the correct and corresponding Sub-Task icon and not always default to the Default?
Hi Carl,
I believe there are actually a pair of bug tickets about this problem of custom issue types not displaying their icon correctly. Please see:
for more details. The later bug ticket appears to have a means to work around this. It seems that after you change an issue type icon, you might be able to then restart Jira as a means to try to get this change to stick and appear correctly in Jira.
Yep. Seems to be a caching issue on the server. We did bounce the server and the correct icon and description are now appearing as desired.
