Showing results forĀ
Search instead forĀ
Did you mean:Ā
Nginx with reverse proxy ssl
nyatse18
July 8, 2019
I managed to work well server installation on localhost:8080 but when I want to put it behind nginx with ssl I can't manage it.
So here is my main nginx conf:
cat nginx.conf
# For more information on configuration, see:
# * Official English Documentation: http://nginx.org/en/docs/
# * Official Russian Documentation: http://nginx.org/ru/docs/
user nginx;
worker_processes auto;
error_log /var/log/nginx/error.log;
pid /run/nginx.pid;
# Load dynamic modules. See /usr/share/nginx/README.dynamic.
include /usr/share/nginx/modules/*.conf;
events {
worker_connections 1024;
http {
log_format main '$remote_addr - $remote_user [$time_local] "$request" '
'$status $body_bytes_sent "$http_referer" '
'"$http_user_agent" "$http_x_forwarded_for"';
access_log /var/log/nginx/access.log main;
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
include /etc/nginx/mime.types;
default_type application/octet-stream;
# Load modular configuration files from the /etc/nginx/conf.d directory.
# See http://nginx.org/en/docs/ngx_core_module.html#include
# for more information.
include /etc/nginx/conf.d/*.conf;
include /etc/nginx/sites-enabled/*.conf;
# server {
# listen 80 default_server;
# listen [::]:80 default_server;
# server_name _;
# root /usr/share/nginx/html;
# # Load configuration files for the default server block.
# include /etc/nginx/default.d/*.conf;
# include /etc/nginx/sites-enabled/*.conf;
# location / {
# error_page 404 /404.html;
# location = /40x.html {
# error_page 500 502 503 504 /50x.html;
# location = /50x.html {
# Settings for a TLS enabled server.
# server {
# listen 443 ssl http2 default_server;
# listen [::]:443 ssl http2 default_server;
# server_name _;
# ssl_certificate "/etc/pki/nginx/server.crt";
# ssl_certificate_key "/etc/pki/nginx/private/server.key";
# ssl_session_cache shared:SSL:1m;
# ssl_session_timeout 10m;
# ssl_ciphers HIGH:!aNULL:!MD5;
# ssl_prefer_server_ciphers on;
# location / {
And here is enabled jira site:
cat sites-enabled/jira.ntsereg.conf
server {
listen 80;
listen [::]:80;
server_name jira.example.com;
# redirect all HTTP requests to HTTPS with a 301 Moved Permanently response.
return 301 https://$host$request_uri;
server {
listen 443 ssl http2;
listen [::]:443 ssl http2;
# certs sent to the client in SERVER HELLO are concatenated in ssl_certificate
ssl_certificate /etc/letsencrypt/live/example.com/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/example.com/privkey.pem;
ssl_session_timeout 1d;
ssl_session_cache shared:MozSSL:10m; # about 40000 sessions
ssl_session_tickets off;
# curl https://ssl-config.mozilla.org/ffdhe2048.txt > /path/to/dhparam.pem
ssl_dhparam /etc/nginx/dhparam.pem;
# intermediate configuration
ssl_protocols TLSv1.2;
ssl_ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384;
ssl_prefer_server_ciphers off;
# HSTS (ngx_http_headers_module is required) (63072000 seconds)
add_header Strict-Transport-Security "max-age=63072000" always;
# root /usr/share/nginx/example.com/html;
# location / {
# index index.php index.html index.htm;
location / {
proxy_set_header X-Forwarded-Host $host;
proxy_set_header X-Forwarded-Server $host;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_pass http://jira.example.com:8080/;
client_max_body_size 10M;
And here is server.xml:
cat /opt/atlassian/jira/conf/server.xml
<?xml version="1.0" encoding="utf-8"?>
Licensed to the Apache Software Foundation (ASF) under one or more
contributor license agreements. See the NOTICE file distributed with
this work for additional information regarding copyright ownership.
The ASF licenses this file to You under the Apache License, Version 2.0
(the "License"); you may not use this file except in compliance with
the License. You may obtain a copy of the License at
http://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software
distributed under the License is distributed on an "AS IS" BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
See the License for the specific language governing permissions and
limitations under the License.
<Server port="8005" shutdown="SHUTDOWN">
<Listener className="org.apache.catalina.startup.VersionLoggerListener"/>
<Listener className="org.apache.catalina.core.AprLifecycleListener" SSLEngine="on"/>
<Listener className="org.apache.catalina.core.JreMemoryLeakPreventionListener"/>
<Listener className="org.apache.catalina.mbeans.GlobalResourcesLifecycleListener"/>
<Listener className="org.apache.catalina.core.ThreadLocalLeakPreventionListener"/>
<Service name="Catalina">
DEFAULT - Direct connector with no proxy for unproxied access to Jira.
If using a http/https proxy, comment out this connector.
<!-- Relaxing chars because of JRASERVER-67974 -->
<Connector port="8080" relaxedPathChars="[]|" relaxedQueryChars="[]|{}^&#x5c;&#x60;&quot;&lt;&gt;"
maxThreads="150" minSpareThreads="25" connectionTimeout="20000" enableLookups="false"
maxHttpHeaderSize="8192" protocol="HTTP/1.1" useBodyEncodingForURI="true" redirectPort="8443"
acceptCount="100" disableUploadTimeout="true" bindOnInit="false"/>
HTTP - Proxying Jira via Apache or Nginx over HTTP
If you're proxying traffic to Jira over HTTP, uncomment the below connector and comment out the others.
Ensure the proxyName and proxyPort are updated with the appropriate information if necessary as per the docs.
See the following for more information:
Apache - https://confluence.atlassian.com/x/4xQLM
nginx - https://confluence.atlassian.com/x/DAFmGQ
acceptCount="100" disableUploadTimeout="true" bindOnInit="false" scheme="http"
proxyName="localhost" proxyPort="80"/>
HTTPS - Proxying Jira via Apache or Nginx over HTTPS
If you're proxying traffic to Jira over HTTPS, uncomment the below connector and comment out the others.
Apache - https://confluence.atlassian.com/x/PTT3MQ
acceptCount="100" disableUploadTimeout="true" bindOnInit="false" secure="true" scheme="https"
proxyName="jira.ntsereg.com" proxyPort="443"/>
AJP - Proxying Jira via Apache over HTTP or HTTPS
If you're proxying traffic to Jira using the AJP protocol, uncomment the following connector line
Apache - https://confluence.atlassian.com/x/QiJ9MQ
<Connector port="8009" URIEncoding="UTF-8" enableLookups="false" protocol="AJP/1.3"/>
<Engine name="Catalina" defaultHost="localhost">
<Host name="localhost" appBase="webapps" unpackWARs="true" autoDeploy="true">
<Context path="" docBase="${catalina.home}/atlassian-jira" reloadable="false" useHttpOnly="true">
<Resource name="UserTransaction" auth="Container" type="javax.transaction.UserTransaction"
factory="org.objectweb.jotm.UserTransactionFactory" jotm.timeout="60"/>
<Manager pathname=""/>
<JarScanner scanManifest="false"/>
<Valve className="org.apache.catalina.valves.StuckThreadDetectionValve" threshold="120" />
</Context>
</Host>
<Valve className="org.apache.catalina.valves.AccessLogValve"
pattern="%a %{jira.request.id}r %{jira.request.username}r %t &quot;%m %U%q %H&quot; %s %b %D &quot;%{Referer}i&quot; &quot;%{User-Agent}i&quot; &quot;%{jira.request.assession.id}r&quot;"/>
</Engine>
</Service>
</Server>
The result of jira.example.com is 504.
Then I tried to change server.xml to:
proxyName="jira.example.com" proxyPort="80"/>
</Context>
</Host>
</Engine>
</Service>
</Server>
With same result. Loading takes 1min.
Kiran Panduga {Appfire}
Hi @nyatse18 ,
In server.xml, you will need to include only the below parameter
scheme="https" proxyName="jira.example.com" proxyPort="443"
Attached a sample nginx configuration for JIRA setup:
{code}
server {
    listen       80;
    location / {
server {
    listen       443 ssl;
    server_name  jira.example.com.com;
    error_log /var/nginx/log/jira.example.com_error.log debug;
    access_log /var/nginx/log/jira.example.com_access.log upstream_time;
    ssl_dhparam /etc/nginx/ssl/dhparm1024.pem;
    ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
    ssl_ciphers '!DHE-DSS-AES256-GCM-SHA384:!DHE-RSA-AES256-GCM-SHA384:!DHE-RSA-AES256-SHA256:!DHE-DSS-AES256-SHA256:!DHE-RSA-AES256-SHA:!DHE-DSS-AES256-SHA:!DHE-RSA-CAMELLIA256-SHA:!DHE-DSS-CAMELLIA256-SHA:!DHE:!MD5:!RC4:!EXPORT:!aNULL:!eNull:!DHE-RSA-AES128-GCM-SHA256:!DHE-RSA-AES128-CBC-SHA256:kEECDH+ECDSA+AES128:kEECDH+ECDSA+AES256:kEECDH+AES128:kEECDH+AES256:kEDH+AES128:kEDH+AES256:+SHA:!aNULL:!eNULL:!LOW:!kECDH:!DSS:!MD5:!EXP:!PSK:!SRP:!CAMELLIA:!SEED:!3DES';#
    location /secure/ForgotLoginDetails.jspa {
        return 301 https://jira.example.com;
    location / {
        client_max_body_size 100m;
        proxy_set_header X-Forwarded-Proto $scheme;
        proxy_pass http://127.0.0.1:8080;
 I hope this works !!!
Kiran.
nyatse18
July 9, 2019
Thanks, your solution worked.
But didn't understand why proxy pass to localhost IP though.
yami
November 12, 2019
I've got "unknown log format "upstream_time" in /etc/nginx/conf.d/main.conf:17"
maybe something has changed
and in your example there's once:
but another time:
That's probably a typo.
That was a typo error. Replace the server_name with your DNS.
Kiran.
Frantisek_Bekes May 27, 2020
thanks
