No change after adding application link to JIRA project in Confluence space
chrisyclam October 30, 2015
Hi, I added an application link to JIRA project in a Confluence space.
A pop up prompted me if link from the JIRA project to Conflence space should be created and select Yes.
It was done without error.
But I cannot see any additional link in the project or space?
Is this feature available on in the cloud version only or may be I am missing something?
Thanks in advance.
Chris
Jobin Kuruvilla [Adaptavist]
October 31, 2015
No links will be created automatically. Once the app links are created, you can now start connecting issues to pages as described here:
https://confluence.atlassian.com/doc/use-jira-applications-and-confluence-together-427623543.html
Vickey Palzor Lepcha
October 31, 2015
You will have to first verify if your application link has been created properly or not . And then think of what you wish to connect between your JIRA and Confluence.
