No output using issue.comments.last in Server Automation
Chris Jost January 26, 2025
Hi all,
I'm looking to send an automated email with the hyperlinked key, summary, and the last comment on an issue. I attached a picture of how it is currently set up. However, in my testing, there is nothing returned for the last comment, despite there being plenty of comments on the issues. Can you please help show me where I went wrong!Screenshot 2025-01-26 224148.png
3 votes
Vishal Biyani
January 26, 2025
@Chris Jost
Since you are using {{issue.comment.last}} inside {{#issues}}, that is one of the problems.
if you take it out and have something like this, it works.
<tr>
<td>{{issue.comment.last.body}}</td>
</tr>
Chris Jost January 27, 2025
Hi Vishal, thank you so much for the reply! Unfortunately that still shows no output: Screenshot 2025-01-27 172843.png
I do have "process all issues in bulk" turned on though
Vishal Biyani
January 27, 2025 edited
@Chris Jost
Below is the working code. You can adjust the message according to your need. You don't need to use issues.comments as you are iterating via issues already.
The {{issues.size}} issues listed below
<table border="1" cellpadding="2" >
<tbody>
{{#issues}}
<tr>
<td><a href {{url}}>{{key}}</a></td>
<td><a href {{url}}>{{summary}}</a></td>
<td> {{comments.author.displayName}} </td>
<td> {{comments.last.body}} </td>
</tr>
</tbody>
</table>
Thanks @Bill Sheboy for your input
Like • 2 people like this
Chris Jost January 28, 2025
Hi all, this may be a silly question but how can I paste my code within here for future reference? Every time I try it gets formatted automatically. Thank you so much for the support as I'm very new to this!
January 28, 2025
For Rich Text...under the "Formats" dropdown there is a "Code block" option for fixed-font.  Yet that "zaps" spacing when pasted in as text...requiring aligning text.
You could also try the HTML format to see if that helps preserve it better.
John Funk
January 26, 2025
Hi Chris - Welcome to the Atlassian Community!
Try {{issue.comments.last.body}}
Hi John, unfortunately this still didn't give an output :( I really appreciate your help!!
January 27, 2025
Hi @Chris Jost -- Welcome to the Atlassian Community!
Your rule is using the bulk-handling smart value {{issues}} to iterate over the issues found.  Once inside the iterator, just use the field's smart value to access it.
For example:
{{#issues}}
* {{key}} -- {{summary}}: {{comments.last.body}}
Hi Bill, unfortunately comments.last.body did not return any output in my format :( I really appreciate the help!!
January 28, 2025
Please re-read my post and the documentation link I provided...
When inside the iterator {{#issues}} ... {{/}} the issue prefix is not used; instead the scope is the iterator.
