No strikeout of issues after they are resolved
David Mudge March 16, 2014
I do not see the identifier of my issues (e.g. ABC-123) being struck out after they are resolved.
My understanding is that the strikethrough should happen to all issues which have a non-empty "Resolution" and to none of the issues where the Resolution field is empty. However I get no strikethrough, no matter what I do to the Resolution field.
Is there something else which determines whether the identifier is struck through?
Thanks.
3 votes
Dave C
September 2, 2014
Issues will appear as a strikethrough when they have a resolution. It's possible for an issue to enter a 'Done' or 'Resolved' or 'Closed' status but not have a resolution - this is entirely dependent upon the workflow configuration. Also as we can see it's possible to have a resolution of 'Unresolved', which is actually a resolution value rather than a null (or empty).
As for issues appearing in the issue navigator, they will not ever be shown as a strike through - this is only applied if the issue is mentioned in comments that use the 'Wiki Style Renderer' as detailed in https://confluence.atlassian.com/display/JIRA/Configuring+Renderers.
So to clarify:
  • JIRA Agile issues will show as a strikethrough when they have a resolution.
  • The issue navigator will not strikethrough issues.
  • Issues in comments will have a strikethrough if JIRA can determine they have a resolution.
Geoff Wilson
April 1, 2016
As a note, I performed a formative usability test on our numerous JIRA changes (and achieving certain goals within JIRA itself to see what we could improve w/ add-ons), and found that often users developed a mental model from their Boards that all closed/resolved issues should appear crossed out / strikethrough.  However, immediately following that they went to the Issue Navigator and were trying to filter by resolved issues and they kept thinking they were doing something wrong / getting the wrong results because all issues displayed were not struck through.  This caused a disconnect in what they expected to see when glancing at a list of issues in distinguishing closed vs open.
No, I have not modified the code.
I believe I am looking at the right field, because up until recently, I had many tasks with strike-through. It turned out that one of the possible values of Resolution in my system was "Unresolved" - i.e. not "this field is empty" rather a string value of "Unresolved". I followed this conversation to figure that out (https://answers.atlassian.com/questions/162136/tasks-crossed-off) and then removed Unresolved as a possible value of the Resolution.
I also had to play around with my Workflows a little, because to remove "Unresolved" as a value, I was sked to nominate another value to set it to - not really helping. So I made a transition in the workflow which had the same source and destination Status, but cleared the Resolution value as a post-function. All that worked fine with the end result that I had cleared Resolution and it was now showing Unresolved, but a true"the Resolution is empty" this time.
Hope all that makes sense.
I include this rather long explanation as possibly this has something to do with my current problem? Since I did that I have not seen strikethroughs in the Issue Navigator.
Another interesting thing I just saw - for some issues even though I see no strikethrough on the Issue Navigator, I do see a strikethrough on the System Dashboard (e.g. in the Activity Stream after I close them).
Moriah Chandler
April 2, 2014
I too am missing strikethrough in the Issue Navigator. It works in JIRA Agile though.
Nic Brough -Adaptavist-
April 2, 2014
If it works in Agile and not in the issue navigator, then you've probably got customised code.
However, you should first check the resolutions are set or not, and you don't have broken resolutions like "unresolved" or "not done"
Moriah Chandler
April 2, 2014
They are set. The reason I know is that if it is truly Unresolved, that word appears in Italics. Any insertion of a resolution is not in italics. (See below)
Custom code for the display? No way. The only thing I have customized (I am the only administrator) are the notification emails. I have custom workflows, yes - but these all set the resolution on Fixed/Closed transition.
April 2, 2014
Hmm, now that's an interesting one. You've got stuff set up correctly as far as I can tell from what you've said (which is pretty detailed).
So, just to confirm, you go into the navigator and pick out an issue which definitely has a resolution set when you go into the issue view, but the issue-id is not struck out?
Moriah Chandler
April 2, 2014
Correct. The issue MOSER-79 on the issue navigator....
And on the Agile board...
Moriah Chandler
April 2, 2014
This is on JIRA 6.0.6 btw. Using the latest Agile.
Wayne September 3, 2020
I also saw this issue. I fixed it based on David Mudge's answer by modifying the flow to 'Done' from the state that did not have the Resolution field set as a post function by adding the post function to set the Resolution to 'Done'.
Max Deinko February 13, 2019
If you created a custom workflow for your project you will need to follow the steps outlined in the link below to have your "done" issue identifiers crossed off in plan mode.
https://confluence.atlassian.com/jirakb/jira-issues-need-a-resolution-826873869.html
Hope this helps. Cheers!
Jeffrey O'Hara
November 23, 2020
Thanks Max...This Worked!!!
Deleted user May 21, 2015
This is how it works for me in JIRA Agile 6.70...
When an issue receives a Resolution, the strikethrough never appears in the issue navigator, nor in JIRA Agile sprint reports. It only appears struckthrough if the issue is on the JIRA Agile Backlog board in an active sprint. This is true regardless of who it was assigned to when closed and resolution set.
Closing and setting resolution for an issue in the backlog removes it from the backlog list on the Agile Backlog board. However, if you edit the issue and put it back in the current active sprint, then it will show on the board as struckthrough.
Dave Merriwether October 23, 2014
We saw this worked when the "assignee" resolved the ticket, but not when someone else did.  If the assignee resolves it, strike-through.  Otherwise, no strikethrough.
Apparently this shows how to make it work as it is working for us now: https://confluence.atlassian.com/display/AGILEKB/Unable+to+set+issues+to+Resolved+using+JIRA+Agile+Simplified+Workflow
docksteaderluke September 2, 2014
I have this same issue. No custom code/CSS. Just custom workflows.
Jeanne Howe
August 10, 2014
Has anyone found a resolution? I have the same problem - resolved issues are not showing strikethrough in the issue navigator or on the issue view screen.
David Mudge April 2, 2014
BTW, I still have the issue too. There are no strikeouts whatsoever in Jira Issue Navigator. But Jira Agile shows the strikeouts as expected.
I also know the code is not modified, as I am the sole admin of a 5 person project, which only began using Atlassian tools a couple of months ago.
I'm on Jira 6.0.7
March 16, 2014
Have you any customisations in the code? (Specifically, the last time this came up, someone had changed the css to deliberately remove the strikethrough - obviously quite dumb as they'd not educated the users about the downgrade).
Also, you are definitely looking at the *system* resolution field? Not a custom field with the same name?
Yes, the values are shown on the UI and vary but they are things like Done, Fixed, etc.
Nazia Tarannum
March 16, 2014
Do you see a value for the Resolution field on the UI for the issue?
