@Component public class DialogServlet extends HttpServlet { private static final long serialVersionUID = 1L; private static final String TEMPLATE = "/dialogTemplate.vm"; private TemplateRenderer templateRenderer; @Autowired public DialogServlet(@ComponentImport TemplateRenderer templateRenderer) { this.templateRenderer = templateRenderer; } @Override protected void doGet(HttpServletRequest req, HttpServletResponse resp) throws ServletException, IOException { Map<String, Object> context = Maps.newHashMap(); String projectName = req.getParameter("projectName"); context.put("projectName", projectName); resp.setContentType("text/html;charset=utf-8"); templateRenderer.render(TEMPLATE, context, resp.getWriter()); } }
atlassian-plugin.xml
<?xml version="1.0" encoding="UTF-8"?> <atlassian-plugin key="${atlassian.plugin.key}" name="${project.name}" plugins-version="2"> <plugin-info> <description>${project.description}</description> <version>${project.version}</version> <vendor name="${project.organization.name}" url="${project.organization.url}"/> <param name="plugin-icon">images/pluginIcon.png</param> <param name="plugin-logo">images/pluginLogo.png</param> </plugin-info> <!-- add our i18n resource --> <resource type="i18n" name="i18n" location="reports"/> <!-- add our web resources --> <web-resource key="reports-resources" name="reports Web Resources"> <dependency>com.atlassian.auiplugin:ajs</dependency> <resource type="download" name="reports.css" location="/css/reports.css"/> <resource type="download" name="reports.js" location="/js/reports.js"/> <resource type="download" name="images/" location="/images"/> <context>reports</context> </web-resource> <web-section name="My Links Main Section" i18n-name-key="my-links-main-section.name" key="my_links_section" location="my_links_link" weight="10"> <description key="my-links-main-section.description">The My Links Main Section Plugin</description> <label key="my-links-main-section.label"/> </web-section> <web-item name="Link on My Links Main Section" i18n-name-key="linkon-my-links-main-section.name" key="my_links_link" section="system.top.navigation.bar" weight="47"> <description key="linkon-my-links-main-section.description">The Link on My Links Main Section Plugin</description> <conditions type="AND"> <condition class="com.organisation.ct.it.conditions.VisibilityCondition"> <param name="group1" value="organisation-inventory-group"/> </condition> </conditions> <label key="Plugins"/> <link linkId="my_links_link">http://www.atlassian.com</link> </web-item> <web-item name="Generare Proces Verbal" i18n-name-key="generare-proces-verbal.name" key="website_link" section="my_links_link/my_links_section" weight="10"> <description key="generare-proces-verbal.description">Generare Proces Verbal</description> <label key="generare-proces-verbal.label"/> <link linkId="website_link">/plugins/servlet/dialogservlet</link> </web-item> <servlet name="Dialog Servlet" i18n-name-key="dialog-servlet.name" key="dialog-servlet" class="com.organisation.ct.it.servlet.DialogServlet"> <description key="dialog-servlet.description">The Dialog Servlet Plugin</description> <url-pattern>/dialogservlet</url-pattern> </servlet> <web-item name="Scanare" i18n-name-key="scanare.name" key="scanare" section="my_links_link/my_links_section" weight="1000"> <description key="scanare.description">The Scanare Plugin</description> <label key="scanare.label"/> <link linkId="scanare-link">/plugins/servlet/scannerservlet</link> </web-item> <servlet name="Scanner Servlet" i18n-name-key="scanner-servlet.name" key="scanner-servlet" class="com.organisation.ct.it.servlet.ScannerServlet"> <description key="scanner-servlet.description">The Scanner Servlet Plugin</description> <url-pattern>/scannerservlet</url-pattern> </servlet> </atlassian-plugin>
pom.xml
<?xml version="1.0" encoding="UTF-8"?> <project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/maven-v4_0_0.xsd"> <modelVersion>4.0.0</modelVersion> <groupId>com.organisation.ct.it</groupId> <artifactId>reports</artifactId> <version>1.0.0-SNAPSHOT</version> <organization> <name>Example Company</name> <url>http://www.example.com/</url> </organization> <name>reports</name> <description>This is the com.organisation.ct.it:reports plugin for Atlassian JIRA.</description> <packaging>atlassian-plugin</packaging> <dependencies> <dependency> <groupId>com.atlassian.jira</groupId> <artifactId>jira-api</artifactId> <version>${jira.version}</version> <scope>provided</scope> </dependency> <!-- Add dependency on jira-core if you want access to JIRA implementation classes as well as the sanctioned API. --> <!-- This is not normally recommended, but may be required eg when migrating a plugin originally developed against JIRA 4.x --> <!-- <dependency> <groupId>com.atlassian.jira</groupId> <artifactId>jira-core</artifactId> <version>${jira.version}</version> <scope>provided</scope> </dependency> --> <dependency> <groupId>junit</groupId> <artifactId>junit</artifactId> <version>4.10</version> <scope>test</scope> </dependency> <dependency> <groupId>com.atlassian.plugin</groupId> <artifactId>atlassian-spring-scanner-annotation</artifactId> <version>${atlassian.spring.scanner.version}</version> <scope>compile</scope> </dependency> <dependency> <groupId>com.atlassian.plugin</groupId> <artifactId>atlassian-spring-scanner-runtime</artifactId> <version>${atlassian.spring.scanner.version}</version> <scope>runtime</scope> </dependency> <dependency> <groupId>javax.inject</groupId> <artifactId>javax.inject</artifactId> <version>1</version> <scope>provided</scope> </dependency> <!-- WIRED TEST RUNNER DEPENDENCIES --> <dependency> <groupId>com.atlassian.plugins</groupId> <artifactId>atlassian-plugins-osgi-testrunner</artifactId> <version>${plugin.testrunner.version}</version> <scope>test</scope> </dependency> <dependency> <groupId>javax.ws.rs</groupId> <artifactId>jsr311-api</artifactId> <version>1.1.1</version> <scope>provided</scope> </dependency> <dependency> <groupId>com.google.code.gson</groupId> <artifactId>gson</artifactId> <version>2.2.2-atlassian-1</version> </dependency> <!-- Uncomment to use TestKit in your project. Details at https://bitbucket.org/atlassian/jira-testkit --> <!-- You can read more about TestKit at https://developer.atlassian.com/display/JIRADEV/Plugin+Tutorial+-+Smarter+integration+testing+with+TestKit --> <!-- <dependency> <groupId>com.atlassian.jira.tests</groupId> <artifactId>jira-testkit-client</artifactId> <version>${testkit.version}</version> <scope>test</scope> </dependency> --> <dependency> <groupId>org.mockito</groupId> <artifactId>mockito-all</artifactId> <version>1.8.5</version> <scope>test</scope> </dependency> <dependency> <groupId>javax.servlet</groupId> <artifactId>servlet-api</artifactId> <version>2.4</version> <scope>provided</scope> </dependency> <dependency> <groupId>org.slf4j</groupId> <artifactId>slf4j-api</artifactId> <version>1.6.6</version> <scope>provided</scope> </dependency> <dependency> <groupId>org.apache.httpcomponents</groupId> <artifactId>httpclient</artifactId> <version>4.1.1</version> <scope>test</scope> </dependency> <dependency> <groupId>com.atlassian.templaterenderer</groupId> <artifactId>atlassian-template-renderer-api</artifactId> <version>1.3.1</version> <scope>provided</scope> </dependency> <dependency> <groupId>org.springframework</groupId> <artifactId>spring</artifactId> <version>2.5.6</version> <scope>provided</scope> </dependency> </dependencies> <build> <plugins> <plugin> <groupId>com.atlassian.maven.plugins</groupId> <artifactId>maven-jira-plugin</artifactId> <version>${amps.version}</version> <extensions>true</extensions> <configuration> <productVersion>${jira.version}</productVersion> <productDataVersion>${jira.version}</productDataVersion> <!-- Uncomment to install TestKit backdoor in JIRA. --> <!-- <pluginArtifacts> <pluginArtifact> <groupId>com.atlassian.jira.tests</groupId> <artifactId>jira-testkit-plugin</artifactId> <version>${testkit.version}</version> </pluginArtifact> </pluginArtifacts> --> <enableQuickReload>true</enableQuickReload> <enableFastdev>false</enableFastdev> <!-- See here for an explanation of default instructions: --> <!-- https://developer.atlassian.com/docs/advanced-topics/configuration-of-instructions-in-atlassian-plugins --> <instructions> <Atlassian-Plugin-Key>${atlassian.plugin.key}</Atlassian-Plugin-Key> <!-- Add package to export here --> <Export-Package>com.organisation.ct.it.api,</Export-Package> <!-- Add package import here --> <Import-Package>org.springframework.osgi.*;resolution:="optional", org.eclipse.gemini.blueprint.*;resolution:="optional", com.atlassian.plugin.osgi.bridge.external, *;resolution:=optional </Import-Package> <!-- Ensure plugin is spring powered --> <Spring-Context>*</Spring-Context> </instructions> </configuration> </plugin> <plugin> <groupId>com.atlassian.plugin</groupId> <artifactId>atlassian-spring-scanner-maven-plugin</artifactId> <version>1.2.6</version> <executions> <execution> <goals> <goal>atlassian-spring-scanner</goal> </goals> <phase>process-classes</phase> </execution> </executions> <configuration> <includeExclude>+com.atlassian.jira.plugins.issue.create.*</includeExclude> <scannedDependencies> <dependency> <groupId>com.atlassian.plugin</groupId> <artifactId>atlassian-spring-scanner-external-jar</artifactId> </dependency> </scannedDependencies> <verbose>false</verbose> </configuration> </plugin> </plugins> </build> <properties> <jira.version>7.1.4</jira.version> <amps.version>6.2.3</amps.version> <plugin.testrunner.version>1.2.3</plugin.testrunner.version> <atlassian.spring.scanner.version>1.2.6</atlassian.spring.scanner.version> <spring.version>2.5.6</spring.version> <!-- This key is used to keep the consistency between the key in atlassian-plugin.xml and the key to generate bundle. --> <atlassian.plugin.key>${project.groupId}.${project.artifactId}</atlassian.plugin.key> <!-- TestKit version 6.x for JIRA 6.x --> <testkit.version>6.3.11</testkit.version> </properties> </project>
1、atlas-clean
2、atlas-mvn package
3、Exception will disappear
From:UnsatisfiedDependencyException/NoSuchBeanDefinitionException for ao service
Hi Oana - what do you mean remove spring? can you please explain what exactly need to do?
Try the newest version of templaterenderer. Update your eclipse project . Are there errors
Not forget to use command like atlas-clean.
Hope this helps.
Hi,thanks for your response.
The last version of templaterenderer that i have found is 1.5.0 but unfortunatly it doens't work.
Is there a newer one?
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
