None option for custom select list
Mark DeMichele
I'm currently using jira 5.0.5. I created a custom field of type select list. I want it to be optional. Thus, I want "empty" to be a valid value. Therefore, I gave it no default value. However, when I put it on a screen, if the user does nothing it seems to automatically select the first item. It has no option for "None". I searched online and people mention a "none" option, but I'm not seeing it. Is this something in a newer version of Jira or am I missing something?
Bharadwaj Jannu
October 8, 2013
I think you made the field as Required while configuring the field. You go to the customfield in field configuration and select as Optional. Then you will see the None option.
Hope this helps and if any doubt ask me back.
Mark DeMichele
Turns out the reason there was no option for None is that in my instance of Jira, the edit-select.vm file did not have the option for None. I'm not sure if someone changed this in the past or that's how it is in Jira version 5.0.5.
RambanamP
October 8, 2013
some possible ways to remove None option from select list
1. some one might be removed None from Vm field ,check this document
https://confluence.atlassian.com/display/JIRA052/How+to+Remove+%27NONE%27+from+a+Select+List+Custom+Field
2. As @Bharadwaj said
None will be removed if field is make required through field configuration and set deafult value for that
3. there is a chance to remove None using javascript
Learn more
