Not able to activate workflow
nitesh-varma July 30, 2019
Hi All,
I am new to jira, I have imported workflow, but not able to associate or activate it.
No option of workflow is visible in project.
How to activate workflow & activate same in project? I tried wiki links, but missing workflow in project.
AwesomeScreenshot-kash786-atlassian-net-secure-admin-workflows-ListWorkflows.jspa-2019-07-31_2_55.png AwesomeScreenshot-kash786-atlassian-net-secure-admin-ViewWorkflowSchemes.jspa-2019-07-31_2_55.png AwesomeScreenshot-kash786-atlassian-net-projects-RUG-settings-details-2019-07-31_2_54.png AwesomeScreenshot-kash786-atlassian-net-secure-admin-workflows-WorkflowDesigner.jspa-2019-07-31_2_22.png
Please advise
Bharath Reddy
Do we have any answer for this. I too don't see any option to activate this.
This video shows to publish in schemes, but that didn't work too
Jack Brickey
The above images are for Next gen projects which do not support Classic workflows.
Bharath Reddy
Thanks Jack. But how do we enable workflow here then.
nitesh-varma July 30, 2019 edited
thanks
Jack Brickey
If you have a workflow in the Inactive list then you simply need to click on “add workflow” in your first scereen. Then find your workflow in the list and add it. Next select which issue types to associate to the new workflow.
Thanks for replying, I did but it also went to inactive state with no option to activate.
Upload screen in reply, please advise is something wrong
Jack Brickey
I'm not following you. Did you click "Add workflow"?
nitesh-varma July 31, 2019
Yes, added workflow but that to went in inactive state, attached screen for reference
AwesomeScreenshot-kash786-atlassian-net-secure-admin-workflows-ListWorkflows.jspa-2019-07-31_10_44.png
Jack Brickey
I just want to be sure you are attempting what I am asking so I will try one more time and be more clear.
Go to your project > project settings > workflows
is the very first screenshot in your question what you see? If you click "Add workflow" on that screen what option are you presented?
Hi Jack,
Tried same, no workflow link present under Project, :(
AwesomeScreenshot-kash786-atlassian-net-projects-RUG-settings-details-2019-07-31_11_27.png AwesomeScreenshot-kash786-atlassian-net-secure-admin-workflows-ListWorkflows.jspa-2019-07-31_11_29.png
On adding new work flow (in Settings => Issues => Work Flow), it goes to inactive list
Jack Brickey
This is a NG project which does not support classic workflow
