I don't think you should try to initiate the ComponentAccessor. You can use it directly like this:
IssueTypeManager itm = ComponentAccessor.getComponent(IssueTypeManager.class);
But prefered way of doing it is to simply specify in the constructor that you will need this object:
public MyPluginComponentImpl(ApplicationProperties applicationProperties, IssueTypeManager itm) { this.applicationProperties = applicationProperties;
Feel free to mark any of my answers as best answers to mark this question as solved if it helped you with your problems :)
BR
Christoffer
If we are talking about the same things, it's also explained here:
https://developer.atlassian.com/pages/viewpage.action?pageId=4227139
/Christoffer
Thank you Christoffer. It helped me, I was able to create custom type. Though, I was getting error that ComponentAccessor is not initialized, even after Ihave made object of it and assigned null value to it. So, I have disabled unit test and everything was fine then. Thanks again.
Can you try to use for example:
or
ComponentAccessor.getComponentOfType(IssueTypeManager.class)
instead of using the Jirautils to load the class?
BR
Christoffer
