×Not able to find an option to increase text field length in advance settings of my JIRA Cloud.
Is it possible in cloud?
Can some one suggest solution.
You won't find it in server either, because you can't do it without rewriting code.
If you need more space in a text field, use the free text field, it's not limited.
