Hi
I am working in the comment section of JIRA bug. i go to the + symbol and pressed on it. I chose user mention and typed in the name of the person. His name did not get added nor worked. I have tried this countless times and nobody in the team can get this feature to work
Can someone help me solve this
Hi Siddhant,
If this is related to a single project, the Browse users permission shouldn't be causing the problem since that is a global permission.
You may want to confirm your Comment field is set to use the "Wiki Style Renderer" renderer in the Field configuration scheme used by this project.
Hi Marcus,
I have the same problem for a single project. In other projects I can use mention.
I verified the browse user permission is given and browse project permission is also given.
Can you help?
Have the same issue. Jira Software 7.0 I can assign all users to a task but certain users I cannnot add to the comment @mention (name just does not appear) > seems like a bug! Most users work. Now permissions, and gliobal permissions are ok. Also all users are on the same group... (8 users work 1 does not) but according to the permissions helper he is configured the same)
Hi Marcus
Thanks so much for ure assistance. This issue has been bothering me for so long and it was problem for the team. I was able to enable now the browse Users permission in JIRA and added all the users who are part of the project. The issue I was having is now solved. Thanks so much for all your help.
Very much appreciated
Hi Sam,
When you try to mention the users, are any users suggested when you start typing?
I believe you may not have the Browse Users permission enabled in JIRA. Please make sure you do have that and verify if the User suggestion is being displayed then.
Cheers
