I am not able to logout of IE10 or IE 11 once i logged into jira cloud I tried deleting cookies and browser still the login session is active
Anyone using IE10 or IE 11 facing the same issue ? how to logout of IE10 or IE 11 ?
-Thanks
Hi Mehul,
I just tested this on Windows Server 2012 with IE11 and I did not run into this issue. Have you tried putting IE in Private browsing mode to see if you can get around this issue? In most cases where I see this the cause is a browser extension, etc. Try Private browsing mode and see if you get differernt results.
Branden
