A colleague of mine created a dashboard from a jira work management project
Currently he is not able to share it with anyone else, as shown as below
The dashboard can only be private
I have been through the JWM documentation and I could not find any information about some limitation about this topic.
Hi @Xavier
Sharing Dashboards and Filters is a Global Permission set in the Jira Administration: Manage global permissions | Atlassian Support
Can you check whether that is enabled?
Hi @Xavier
As @Rebekka Heilmann _viadee_ mentioned, you can check if your Admin has restricted who can share filters/dashboard.
Go to https://xyz.atlassian.net/secure/admin/GlobalPermissions!default.jspa where xyz is your instance.
Discuss with your admin to get permissions sorted out
Additionally, for anyone not particularly familiar with this UI, you can enable dashboard sharing settings for only groups, not individuals.
And the way to add new groups to the "Share dashboards and filters" setting (or any setting on this page) is:
