This is the condition you need
changeItems.any{
it.field == 'Sprint'
This filter pulls up the data we need, and then if there is a change to this filter we need a notification: project = PULSE AND issuetype = Story and status = ready AND resolution = Unresolved and Sprint not in futureSprints()
The right event should be Issue Updated. Could you try to change the event from Issue Moved to Issue Updated?
Basically you are updating an issue field that reflects the current sprint. If you move your issue that field should not be affected.
Since we have multiple sprints this is notifying too often. Is there a way so a notification is sent only if the issue is a Story and only if the issue is moved in/out of the active sprint? This condition does not appear to work: project = PULSE AND issuetype = Story AND status = Ready AND resolution = Unresolved and Sprint not in futureSprints()
Hi Amy. Did you ever figure a way to accomplish a notification being sent if the issue is moved in/out of the active sprint? If so, would you mind sharing your script? Thanks!
Your condition is a JQL query.
Scriptrunner handles groovy scripts so the native way should be something like:
def sprintChanged = changeItems.any{
sprintChanged && issue.projectObject?.key == "PULSE" && issue.issueTypeObject?.name == 'Story' && issue.statusObject?.name == 'Ready' && issue.resolutionObject?.name == 'Unresolved'
