NullPointerException when Table Grid Editor by iDalko is enabled
sajsyed May 3, 2015
hi
I am getting null pointer exception when  Table Grid Editor by iDalko plugin is enabled.
I am attaching the log after enabling debug mentioned here(http://confluence.xpand-it.com/display/XPORTER/FAQ)
Please see attached debug log and test template.
NOTE: Please see in the log   .., at first when  Table Grid Editor plugin is enabled it gave me an exception.After disabling the plugin i am able export successfully.
Any help would be appreciated.
Rui Rodrigues
May 5, 2015
Hi Francis, When Xporter is getting the Issue Html View value from the Table Grid custom field, that value is null.
sajsyed May 5, 2015
Hi Francis,
I have reported the issue at Xporter service desk(http://jira.xpand-it.com/servicedesk/) and get it resolved yesterday with new build which he gave it to me .Now i am able to export the documents with the help of xporter plugin.
However , with further communication with xporter developer  i got below response for exporting table grid values.
Rui Rodriguez
Yesterday 1:38 PMLatest
Correction:
${idalko-tablecustfield1|html=true}
For further information you can see our documentation here.
The problem is not related with that.
When Xporter tries to get the value from Table Grid custom field, the value is null. So, I think the problem is not on our plugin. I added some logging on version I sent you this morning, as you can see on log file there are messages like this one:
2015-05-05 15:07:19,105 http-bio-8080-exec-21 ERROR amsdev 907x1060x1 hmm9ok 0:0:0:0:0:0:0:1 /plugins/servlet/jiraxporter [xpandit.jiraxporter.utils.FieldMapper] Unable to get IssueHtmlView from Table Grid or Xray Test Steps.
Could you check this problem with Table Grid support please?
Thank you.
I am using trial version of idalko plugin.It would be great , if idalko supports the exporting custom fields with xporter plugin.Could you please help me on this ?
francis
Can you forward this case to support.tge at idalko.com ? This will create an issue on our JIRA and an account for you. IssueHtmlView should not return a null. Once fixed we can report back in this channel. Francis
sajsyed May 5, 2015
Hi Francis, I am not able to access https://support.idalko.com. could you please create issue for me and know the status here . Thanks Sajid
francis
Just forward the case to support.tge@idalko.com, which will create an account and raise a ticket.
sajsyed May 11, 2015
Hi Francis, Any update on this ?
francis
It is being handled as a support case, we will report back here once issue is fixed.
sajsyed June 20, 2015
hi Francis, Any update on this ??
francis
Hmm - your ticket on our system was marked as resolved. Due to some quirck, your reply on our request for feedback went unnoticed It's now back on our radar with an elevated priority Sorry about that, thanks for elevating it. Francis
I have a requirement to export the grid in pdf/doc with custom formatting( I am using xporter plugin) . could you please let me know syntax how can I achieve it with table grid editor and xporter. Please let me know syntax if I have to use groovy scripts which you have mentioned here(https://wiki.idalko.com/display/TGPD/Using+scripted+fields+to+extract+information+from+the+grid ). Regards, Sajid
francis
Nope - this is related to the integration between the two plugins. Apparently the IssueHtmlView is returning null in your case, which it shouldn't. Trying to understand the circumstances when this happens is subject of the support request which we track in our jira. You don't need to use the groovy script approach.
francis
For the xporter people - what is com.xpandit.jiraxporter.utils.FieldMapper.formatCustomField doing ?
