Number of elements in variable
Krzysztof Hotiuk September 22, 2019 edited
Is any possibility to check how many elements are stored in variable ?
ex.
uprawnienia="jeden, dwa, trzy" -> it should tell, that here are three elements
uprawnienia="jeden" -> it should tell, that there is one element.
I'm looking for something like this in JQL:
project="jakisprojekt" and numberof(uprawnienia)=1
I know, that it isn wrong statement but looking for something similar.
any idea?
I have "jira automation plugin". if I can use it, let me know how?
Krzysztof
Nic Brough -Adaptavist-
September 23, 2019
You'll need something that can be used to write a new "JQL function".  Automation cannot do that, you'll need one of the full Scripting apps to do that (or write your own app)
Another option might be a scripted field that simply returns issue.getCustomFieldValue(cf).size() - then you'll be able to say things like "and uprawnienia-count > 2" in plain JQL.
Register now
