Numeric Custom Field - Increase the number in a post function
MajoG
I used to add a post function to increase the value of a numeric custom field.
Does still exists?
Regards, Mage
Jobin Kuruvilla [Adaptavist]
March 24, 2014
Make sure the JIRA Misc Workflow Extensions plugin is enabled under Administration > Manage Addons. If so, you can use "Increase value of field" function.
MajoG
Thanks a lot Jobin! It was that my problem, I didn't had the addon.
Neil Arrowsmith
March 24, 2014
Alternatively you can script it with the Script Runner plugin.
