Hi Committe,
I am trying to use the below code to create a new project in my jira,
using System.Text;
using System.Net.Http;
using System.Json;
using System.Web.Script.Serialization;
namespace Test
class Class1
public void Create()
string message = "Hai \"!Hello\" ";
string data = "{\"fields\":{\"project\":{\"key\":\"TP\"},\"summary\":\"" + message + "\"}}";
System.Net.Http.HttpClient client = new System.Net.Http.HttpClient();
client.DefaultRequestHeaders.ExpectContinue = false;
client.Timeout = TimeSpan.FromMinutes(90);
byte[] crdential = UTF8Encoding.UTF8.GetBytes("adminName:adminPassword");
client.DefaultRequestHeaders.Authorization = new System.Net.Http.Headers.AuthenticationHeaderValue("Basic", Convert.ToBase64String(crdential));
client.DefaultRequestHeaders.Accept.Add(new System.Net.Http.Headers.MediaTypeWithQualityHeaderValue("application/json"));
System.Net.Http.HttpContent content = new StringContent(data, Encoding.UTF8, "application/json");
try
client.PostAsync("http://localhost:8080/rest/api/2/issue",content).ContinueWith(requesTask=>
try
HttpResponseMessage response = requesTask.Result;
response.EnsureSuccessStatusCode();
response.Content.ReadAsStringAsync().ContinueWith(readTask =>
var out1 = readTask.Result;
Console.WriteLine("-----> Name :------- Project Name : ");
catch (Exception exception)
Console.WriteLine(exception.StackTrace.ToString());
Console.ReadLine();
Console.WriteLine(Environment.NewLine + "Name : Project Name : ");
catch (Exception exc)
It throws the issue like below:
"{\"errorMessages\":[\"Unexpected character ('!' (code 33)): was expecting comma to separate OBJECT entries\\n at [Source: org.apache.catalina.connector.CoyoteInputStream@1ac4eeea; line: 1, column: 52]\"]}"
But i use the same json file in Firefox Poster , i have created the issue.
Json file : {"fields":{"project":{"key":"TP"},"summary":"Hai \"!Hello\" "}}"
I am also used the issue type value, please refer the Json file
{"fields":{"project":{"key":"TP"},"summary":"Hai \"!Hello\" ","issuetype":{"name": "Bug"}}}"
In FireFox poster create the new issue in Jira, but through the given code issue is not created.
