Hi, I would like to import data from discovery zip file. Bu t I am gettng an error like this:
"Failed to read object schema description, Details: /obss/tmp/atlassian/jira/insight_import8483849100840563348/export-details.properties (No such file or directory)"
And I didn't find an info about this situation for the docs.
Could you help to us for this operation.
Thanks for now.
Hi Muhammet,
Thank you for submitting this Request in our portal as well - we will continue our discussion there.
For the Community's sake:
The Error results from an attempt to import an Insight Discovery Scan Result using the Object Schema Import Functionality - hence the Data format prevents the Schema Import from running correctly.
A Discovery Scan Result ZIP should be imported into Insight using a Discovery Import, preferably configured in an empty Object Schema where you can configure your Import, followed by creating a Predefined Structure (Object Types) and a Predefined Configuration (Object Type Mapping) - then the Scan Result ZIP will be successfully imported into Insight - resulting in Objects created in the different Object Types, according to the Scan Results.
Yinon
Team Riada
The links "Predefined Structure" and "Predefined Configuration" don't work. Is there a new location for these instructions for insight latest version?
Hi Heather.
Predefined Structure, followed by the Predefined configuration in our documentation.
Best regards,
Yinon
Mindville Support Team
