we are going to adopt JIRA (cloud) and replace Mantis as an issue tracking tool (not just that, of course, but just that for the sake of this question).
Our Mantis instance is hosted, not on premise. We have an access to the portal URL, and we can obtain a dump of the DB.
I read the post here https://confluence.atlassian.com/adminjiraserver/importing-data-from-mantis-938847610.html and I seem to understand that the tool needs a direct access to Mantis' DB.
Could anyone suggest a way to offline import our Mantis DB data, that is without having any connection to the internal DB ?
Thank you
Hi Pierangelo,
The Mantis Importer is only available on Jira Server and not on Jira Cloud, but as you noted Yes it does require a connection to the Mantis system.
If you did want to use the Mantis Importer tool as its only available for Server, it would add in some additional complexity but could still be done, I would Recommend setting up a temporary trial of Jira Server, migrate the data across with the Mantis Importer tool, Then Migrate the data from the temporary Server to Jira Cloud
But overall I believe it would be much simpler to us a CSV import. importing Mantis to Jira Cloud, you would be best off converting the data to a CSV and import as covered in Migrating from other issue trackers.
Additional Details on CSV imports can be seen here
Earl
Hi Earl
In the case of CSV import, how will we handle the attachments which is part of the Mantis.
Please advice.
Prince
Hi princejhcl,
did you find a solution for the export of the attachments?
