One project; multiple teams, running parallel sprint
Raju AD September 26, 2017
How can we ahve Multiple or Parallel Sprints running at the same time.
I saw some where, we can do the settings change in JIRA Administration >> Applications >> JIRA Software >> JIRA Software Labs and then mark the checkbox named Parallel Sprints,
But being a JIRA admin, i couldn't find the "Applications" option, Can some one help me for this.
Peter DeWitt
Nagaraju, Not sure what version of JIRA you are using but on 7.3.x + you will need to look here:
1. Click on the little gear drop-down (upper right-hand corner)
2. Select Applications
3. On the left side under JIRA Software select JIRA software configuration.
4. there will be a checkbox to check.
After this all you need to do is create you sprints and start as many as needed.
Good luck!
-pd
Raju AD September 26, 2017 edited
Thanks Pete for the response...But ours is JIRA v6.3. How can we do this in 6.3?
Register now
