I can't see Oracle 13 g at the supported platforms list at
https://confluence.atlassian.com/display/JIRA060/Supported+Platforms
Do anybody know if Oracle 13g will work fine with Jira 6.0.4?
Thanks in advance
Hi Flacid,
Oracle 13g is not yet supported meaning that our Developers have not tested and fix any version related issues. It might work for you but there is high chancess you might encounter issues along the way. Lets see if any one has a positive feedback from the community on their trial. I will generate not advice using unsupported platforms due to support policy. Thanks
Sultan
