Oracle SQL Query to fetch Users from database
Shaikh Moiz
Hello folks,
I am not able to get users list from backend,
I am following the KB as,
https://confluence.atlassian.com/display/JIRAKB/How+to+Get+a+List+of+Active+Users+Counting+Towards+the+JIRA+License
and getting the error table or view does not exists,
we want to get the user list with thier last login details,
any help is appreciated,
Moiz Shaikh.
Nic Brough -Adaptavist-
March 2, 2014
What user directory are you using? Are you sure your database is the right one? Are you looking in the right tables for your version of Jira?
Shaikh Moiz
Hello Nic,
we are using Jira's default internal directory. No external directory like crowd or LDAP we are using.
March 2, 2014
Ok, and which version of Jira? It matters because the user handling changed between 2 and 3, and 4.2 and 4.3
March 2, 2014
What user directory are you using? Are you sure your database is the right one? Are you looming in the right tables for your version of Jira?
