Order by Priority in the backlog
Supriya January 29, 2020
I am trying to add a filter that Orders all backlog items by their priority. Highest,high,medium,low..etc
project = "RTN" ORDER BY Rank DESC - Did not work
project = "RTN" ORDER BY Priority DESC - Did not work
How can I sort the backlog based on the items priority?
Nic Brough -Adaptavist-
January 29, 2020
This sounds like you are trying to use a quick filter to order the issues.  Quick filters do not do ordering, they are just for filtering out sub-sets of already selected (and ordered) issues.  Only the board menu controls the order, and should be set to "Rank" in most cases (otherwise you can't rank issues)
Nic - Thank you. I was able to create a filter inside issues and it works as intended.
But this is inside the project. Not at backlog level. Can I create some filter that works at backlog level?
January 29, 2020
Boards work off filters like "project = "RTN" ORDER BY Rank DES"
You'll need to explain why "it does not work", as it works for everyone else and we don't know your actual symptoms.
Supriya January 30, 2020
Nic - I am not sure if I am following you. You mentioned quick filters won't work to filter by priority.
So when I created filter by clicking on Board-->Configure-->QuickFilters
OrderbyPriority JQL="project = "RTN" ORDER BY Rank DESC"
JQL="project = "RTN" ORDER BY Priority DESC"
Back to board --> I click on Order by Priority Nothing happens.
when I go to Project -->Issues --> project = "RTN" ORDER BY Priority DESC
I save this filter as Order by Priority It works inside the project Issues.
I want this filter to work in the backlog area.
How can I create a filter that orders the items in the backlog ?
January 31, 2020
You say "You mentioned quick filters won't work to filter by priority."
No.  I did not say that.  I said that they will not SORT.  Please re-read "Quick filters do not do ordering, they are just for filtering out sub-sets of already selected (and ordered) issues."
Yes, that's because quick filters won't work for sorting.
> when I go to Project -->Issues --> project = "RTN" ORDER BY Priority DESC , I save this filter as Order by Priority It works inside the project Issues.
Yes, it will work, that's what the searches are for.
>I want this filter to work in the backlog area.  How can I create a filter that orders the items in the backlog ?
Not a problem, set that as the board filter.  You won't be able to rank, but you'll get the sorted list that way.
Like Supriya likes this
Tapani Saarinen
June 9, 2024
Jira so much sucks. It can't even do a simple list sorting. Atlassian should hire a UX expert.
Supriya February 10, 2020
Thank you Nic. This is what I was looking for. A Board filter.
