Order of field on cards on board
Stu
On my cards, that display on my board, there is summary, name then priority.
Is it possible to reorder this, so its Name then Summary, and no priority?
Jonny Adams
April 2, 2018
@Stu Summary will always be at the top of a card, but you should be able to remove Priority from "Card Layout".
@Anup Issue Detail View only pertains to the detail view which appears to the right of all columns on a board when you select one of the cards.
Jonny Adams
April 4, 2018
@Stu were you able to get Priority cleared from your cards?
Stu
@Jonny Adams yes I was able to remove that.  Thanks
Anup
April 2, 2018 edited
I believe those fields are default and those can't be changed around.
Go to your board > Board Settings > Card Layout
The only options I see are to add a further 3 fields and re-arrange them as desired.
If you're using JIRA server, you may be able to find an Issue Detail View section where you may be able to re-arrange as desired.
Stu
ok thanks guys
Register now
