Order of issues in schedule
Phil January 22, 2019
which factors influence the order of the issues in the schedule? Can I influence the order manually?
Thanks and regards,
Phil
Earl McCutcheon
January 22, 2019
Hi Phil,
This is covered in more detail in Scheduling behavior, but there is a list of possible Factors on the document, then in your instance on each issue under the 'Scheduling factors' section of the Scope view, there a list of factors that apply to the issue with a note on how to influence that factor by hovering over the Earlier or Later hyperlinks in the "How do I move this issue earlier or later" comment at the bottom.
Earl
Phil February 13, 2019
Hi Earl,
thank you for your answer.
To be more precicely: how can I influence the order of the issues in the schedule in a vertical way? In the scope-"list" the issues are sorted by title (which is basically by issues ID). Can the issues in the schedule also be sorted by title (issue id). Otherwise we have to search for the issues in the schedule.
Thanks in advance and regards,
Phil
atlassian, atlassian community, loom ai, atlassian loom ai, loom, atlassian ai, record recaps of meetings, meeting recaps, loom recaps, share meeting recaps,
Loom’s guide to great meetings 📹
Register today!
