Output API successful call response to ticket comment?
Eric Smith
I am attempting to define a successful call response from an API and output it to a Jira comment. However, I keep getting the same error message:
2019-06-19 19:58:25,551 http-nio-8080-exec-5 url:/secure/WorkflowUIDispatcher.jspa username:esmith DEBUG esmith 1198x73906x1 1pjq8zi 10.233.231.48,10.231.220.22 /secure/WorkflowUIDispatcher.jspa [c.o.j.groovy.groovyrunner.spring] BeforeInstantiation [bean=com.onresolve.jira.groovy.GroovyFunctionPlugin, type=com.onresolve.jira.groovy.GroovyFunctionPlugin]
2019-06-19 19:58:25,552 http-nio-8080-exec-5 url:/secure/WorkflowUIDispatcher.jspa username:esmith DEBUG esmith 1198x73906x1 1pjq8zi 10.233.231.48,10.231.220.22 /secure/WorkflowUIDispatcher.jspa [c.o.j.groovy.groovyrunner.spring] AfterInitialisation [bean=com.onresolve.jira.groovy.GroovyFunctionPlugin, type=com.onresolve.jira.groovy.GroovyFunctionPlugin]
2019-06-19 19:58:25,557 http-nio-8080-exec-5 url:/secure/WorkflowUIDispatcher.jspa username:esmith ERROR esmith 1198x73906x1 1pjq8zi 10.233.231.48,10.231.220.22 /secure/WorkflowUIDispatcher.jspa [c.o.s.jira.workflow.ScriptWorkflowFunction] *************************************************************************************
2019-06-19 19:58:25,558 http-nio-8080-exec-5 url:/secure/WorkflowUIDispatcher.jspa username:esmith ERROR esmith 1198x73906x1 1pjq8zi 10.233.231.48,10.231.220.22 /secure/WorkflowUIDispatcher.jspa [c.o.s.jira.workflow.ScriptWorkflowFunction] Script function failed on issue: TPPI-495, actionId: 61, file: <inline script>
groovy.lang.MissingPropertyException: No such property: event for class: Script467
at Script467.run(Script467.groovy:23)
My code is here, the main interesting bits are near the bottom:
@Grab(group='org.codehaus.groovy.modules.http-builder', module='http-builder', version='0.7.1')
import groovyx.net.http.HTTPBuilder
import static groovyx.net.http.ContentType.*
import groovyx.net.http.ContentType
import groovyx.net.http.Method
//import static groovyx.net.http.Method.*
import static groovyx.net.http.Method.PATCH
//import static groovyx.net.http.ContentType.JSON
import com.atlassian.jira.ComponentManager
import com.atlassian.jira.issue.CustomFieldManager
import com.atlassian.jira.issue.IssueManager
import org.apache.log4j.Category
def Category log = Category.getInstance("com.onresolve.jira.groovy")
log.setLevel(org.apache.log4j.Level.DEBUG)
Issue sourceIssue = event.getIssueLink().getSourceObject()
Issue issue = event.issue
def issueManager = ComponentAccessor.getIssueManager()
def CommentManager = ComponentAccessor.getCommentManager()
def currentUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
def ComponentManager = ComponentManager.getInstance()
//Call the School URL field from the ticket
def schoolUrl_field = customFieldManager.getCustomFieldObject("customfield_12456")
// Get the value of the School URL field from schoolURL
def schoolUrl_value = issue.getCustomFieldValue(schoolUrl_field).toString()
//define CNAME entry based on School URL field first octet
def siteName = schoolUrl_value.tokenize(".")[0].toString()
//Define domain based on the School URL field second octet
def siteDomain = schoolUrl_value.tokenize(".")[1].toString()
//Get the value of the Shard field
def shard_field = customFieldManager.getCustomFieldObject("customfield_12454")
// Get the value of the Shard field from schoolURL
def shard = issue.getCustomFieldValue(shard_field).toString()
//Bring them together
def content = "owsoo${shard}.${siteDomain}.com.".toString()
def name = "${siteName}.${siteDomain}.com.".toString()
def dig = "dig ${schoolUrl_value}".execute().text
def comment_success = "School added to DNS \n ${dig}"
def comment_failure = "Adding school to DNS failed. See logs for more info"
def http = new HTTPBuilder("http://[IP_ADDRESS][PORT]/api/v1/servers/localhost/zones/[domain].com")
http.request(PATCH,ContentType.JSON) {
headers."X-API-KEY" = "[API_CALL]"
headers.contentType = "application/json"
body = [
"rrsets": [
"name": name,
"type": "CNAME",
"ttl": 300,
"changetype":"REPLACE",
"records": [
"content": content,
"disabled": false
response.failure = { resp, reader ->
[response_failure:resp, reader_failure:reader]
response.success = { resp, reader ->
[response_success:resp, reader_success:reader]
def response_success = http["response_success"]
def response_fail = http["response_fail"]
def reader_success = http["JSON_success"]
def reader_failure = http["JSON_failure"]
if (response_success == true) {
CommentManager.create(issue, currentUser,comment_success, true)
else {
CommentManager.create(issue, currentUser,comment_failure, true)
What am I doing wrong? I am trying to define a variable in HTTPBuilder, swap it out of HTTPBuilder, and then input it in a comment in the issue that kicked off the post-function
Marc Minten (EVS)
June 20, 2019
Where do you use your script ? In a workflow ???
I think the "event" variable is only available in a Listener script...
Eric Smith
Yes, I am calling it in a post-function
Marc Minten (EVS)
June 20, 2019
...I think in that case you directly should use "issue" in stead of "event.issue"....
Eric Smith
Are you talking about these lines?
If I remove event I dont think they are going to work. Whats the normal method to refer to the issue that is executing the transition? I usually use JMWE which uses originalIssue I believe.
Marc Minten (EVS)
June 20, 2019
Yes, you can simply remove both lines. "sourceIssue" is never used in your script, and the method getIssueLink() doesn't even exist on an event, so that line is meaningless anyway.
In workflow scripts you can refer to the issue in transition by "issue"
Eric Smith
It worked!
I must have left getIssueLink() in from a previous iteration, the Issue one was all on me as I used it before in a listener and thought it carried over. Thanks for the response!
Let's build A Rovo Agent 🤖
Save your spot
