PDF Export integration with Sharepoint
Jorge Jerez
Hi
Anyone knows any plugin to automate a process following the next:
When a Issue is closed, we make a PDF Export and save the PDF on a Share Poing, we're using Agile Cards actually to create the PDF.
Aron Gombas _Midori_
January 7, 2020
I'm not sure if Sharepoint can pick the files from the filesystem or from email, but if any of these channels work, then you can do this:
  1. Use the Better PDF Exporter app (to take care of the document generation)
  2. Use the Better PDF Automation app (to provide the automation actions)
  3. Use the Automation for Jira app and create an automation rule which...
    1. Is started at the "issue closed" events
    2. Creates the PDF and writes that to the file system (or emails that)
  4. Use SharePoint to pick up the file produced by point 3
See this tutorial video: http://youtu.be/sdt5wWrvy8k?autoplay=1
Also see this tutorial article: https://www.midori-global.com/products/better-pdf-automation-for-jira/server/documentation/
