PSQLException relation does not exist. Active Objects
Mathieu Yargeau April 4, 2017
I am trying to save a relation between two objects. AT is an object that will have a Many to Many relationship with CT (which is an interface really, AT will actually have a relationship with with entities inheriting from CT, IT for example).
public interface AtToCt extends Entity {
    public AT getAT();
    public void setAT(AT at);
    public CT getCT();
    public void setCT(CT ct);
@Polymorphic
public interface CT extends Template {
    @ManyToMany(value = AtToCt.class)
    public AT[] getATs();
public interface AT extends Template {
    public CT[] getCTs();
public interface IT extends CT { }
@Polymorphic
public interface Template extends Entity { }
Here is the code saving the relation
final AtToCt atToct = ao.create(AtToCt.class);
atToct.setAT(at);
atToct.setCT(ct);
atToct.save();
The first line gives me an exception. The `ct` variable is an instance of `IT`. Both `at` and `ct` are valid entities taken from the database. `ao` is the ActiveObjects component from JIRA.
There was a SQL exception thrown by the Active Objects library:
Database:
- name:PostgreSQL
- version:9.4.11
- minor version:4
- major version:9
Driver:
- name:PostgreSQL Native Driver
- version:PostgreSQL 9.4.1212
org.postgresql.util.PSQLException: ERROR: relation "public.AO_C3F116_AT_TO_CT_ID_seq" does not exist
Position: 16
Arda Koç December 23, 2020
Did you get any solutions for that exception?
Ana Retamal
May 8, 2017
Hi Mathieu! For this kind of question, it would be better to submit it to our Developer Community. You can find them at community.developer.atlassian.com.
Hope this helps :)
Ana
Help us plant more trees
