Parent - Subtask Comments Sync
Fariz Aliverdiyev
Hello.
I need to sync comments between parent task and subtasks. I know that this can be done with Automation for Jira Pro, but we don't use it. Is there a way to sync comments with JWT Automation Rules? Or maybe there is an example of script for this ?
Thank you in advance.
3 votes
Vishwas
December 24, 2021
Hi @Fariz Aliverdiyev
Yes it's possible, I just tried with JWT automation rules and it worked successfully too.
Please find the configurations I had done. This rule copies comments from Parent issue to sub-tasks.
Hope this helps !
Vishwas
Thorsten Letschert _Decadis AG_
Hey @Vishwas
While the solution is almost correct, you should move the selector to be placed within the condition block. Executed like shown, the selector and comment part would be executed regardless of the condition's result.
Thorsten
Like Vishwas likes this
Vishwas
December 24, 2021
Hi @Thorsten Letschert _Decadis AG_
ahh !! . I missed that part, I understand now. Thanks !
Vishwas
Like # people like this
