I am trying to compare two dates to each other
How I am doing this is:
//To get the actual DATE
def today = new Date().format('yyyy-MM-dd hh:mm:ss')
//To define the Done DATE and TIME
def done = issue.get("fixVersions").startDate.toString()
if ((today) < (done)) {
true
else{false}
This technically works to compare the dates, but if I want to add time to the FixVersion start date, I need to convert the string to a date object. I have tried to do that by changing the code to:
//To define the done DATE and TIME
def doneDate = new Date().parse("yyyy-MM-dd hh:mm:ss", done)
However, this fails with the following error:
java.text.ParseException: Unparseable date: "[2021-02-28 00:00:00.0]"
Any idea what I'm doing wrong here?
Hi @Steve Beauchamp , I think "fix versions" is Collection of values (https://docs.atlassian.com/software/jira/docs/api/8.12.0/com/atlassian/jira/issue/Issue.html#getFixVersions--), so what groovy does is:
So you probably need something like, because startDate is of Date type (https://docs.atlassian.com/software/jira/docs/api/8.12.0/com/atlassian/jira/project/version/Version.html#getStartDate--):
Thanks! This worked perfectly. I just had to modify it slightly to compare the date + 16h to 'today'.
The final code I used was:
def doneDate = issue.getFixVersions().get(0)?.startDate.format('yyyy-MM-dd')+" 16:00:00"
if ((today) < (doneDate)) {
true
else{false}
