Hello Every one ,
I'm looking for a solution to convert a text field into a date-time format.
For example, I have a Text 3 field with a value like: 12/02/2025 13:51:21
I need a smart value that can save this value into a date-time field. The default format on my instance is dd/MMM/yyyy h:mm a
I'm using .toDate
, but it’s not working until I change my text field value to 12/Feb/2025
. Do you know a way to convert a text field when its format differs from the instance's default date format?
with toDate you need to specify the format. Are you doing that?
Once string is converted to date, use .format to update the date format
.toDate("yyyy-MM-dd").format("MM/dd/yyyy H:m:s ")
Finnaly i'm able to using this smart value and save to date time field
.ToDate("dd/MM/yyyy HH:mm:ss")
Good to know that this worked for you
