I'm retrospectively adding project categories to projects in line with organisation structure.
Project Category Examples
IT (department level)
IT-ES (section level)
IT-ES-SAS (team level)
JQL Example
Looking for a quick way to report across the board, so I was hoping to be able to do a partially match category to return issues belonging to projects categorised as IT-ES or IT-ES-SAS
category ~ "IT-ES*"
The operator '~' is not supported by the 'category' field.
Do I need to (can I) copy this value into a custom field of an appropriate type, make that field available globally and query on that?
I should have mentioned I was planning to go with that option for my immediate need.
i.e. Reporting for my group of teams IT-ES* for which there are a finite number of sub-categories.
category IN (IT-ES-A, IT-ES-B, IT-ES-C)
My ability to roll this approach further across the organisation would be limited though, so I was looking for something more dynamic.
